Repairing Nespresso Aeroccino Plus Motor
  1. Repairing Nespresso Aeroccino Plus Motor, Heat: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
  2. Repairing Nespresso Aeroccino Plus Motor, Open: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Nespresso Aeroccino Plus Motor, Open: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the bottom with a strong screwdriver. Be careful not to break the clips inside
  3. Repairing Nespresso Aeroccino Plus Motor, Prepare: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Nespresso Aeroccino Plus Motor, Prepare: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
  4. Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
    • If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
    • If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
  5. Repairing Nespresso Aeroccino Plus Motor, Close: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic three times. At last switch must be pressed in.
To proof the function use water.
crwdns2935229:036crwdne2935229:0
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
293.806 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2947412:049crwdne2947412:0
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
jschiedermair - crwdns2934203:0crwdne2934203:0
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
jeroenvaneijk - crwdns2934203:0crwdne2934203:0
Yes, it's a miracle. :-)
VauWeh -
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao -
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
Georg Sunkler - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 58
crwdns2936753:07crwdne2936753:0 390
crwdns2936753:030crwdne2936753:0 1,397
crwdns2942667:0crwdne2942667:0 118,307
