Repairing Dolce Gusto Melody Water Seal
  1. Repairing Dolce Gusto Melody Water Seal, Repairing Dolce Gusto Melody Water Seal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to unplug the device before you begin the procedure.
    • Remove the 6 screws from the back.
  2. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull at the top of the rear cover.
  3. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Dolce Gusto Melody Water Seal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the dirty seal inside
  4. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Dolce Gusto Melody Water Seal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the rubber seal and the filter.
  5. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Dolce Gusto Melody Water Seal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the inside of the cover, the rubber ring, the filter and the holder of the rubber and filter.
  6. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Dolce Gusto Melody Water Seal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put it all back together... First the filter, then the rubber ring... You need the smooth side of the ring facing up.
  7. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hook back in the back cover, be careful not to break the clip at the bottom
  8. Repairing Dolce Gusto Melody Water Seal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Back together... And you are ready to make some coffee...
In case you notice the water seal rubber is broken or has tiny cuts in it. You can re-order part: MS-0907124 - Krups Seal
crwdns2935229:017crwdne2935229:0
abc
crwdns2935283:008/22/13crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Hi! I do have that problem and that is probably the reason why it leaks as I live in an area of very hard water.I am trying to follow your instructions but I can find the right screwdriver to open it up.Do you know how do they call the bit I need to open it up?thanks
Cfernandez - crwdns2934203:0crwdne2934203:0
Really helpful - thanks so much I think it has done the trick !
I didn't think I had the right screwdriver but then found it in a kit I bought recently.
traceyhealey - crwdns2934203:0crwdne2934203:0
Thanks! The same seal worked also with De Longhi EDG 600.B
Giulio Malventi - crwdns2934203:0crwdne2934203:0
Hi, just taken mine apart and although no crud on the seal I did notice that it was lower than the clear plastic suround it sits in. Either the seal isn't deep enough or its shrunk over time, hence the leak. Oh yes there are in fact 8 screw's in the black outer housing. Hope this helps.
Alan Stubbs - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 204
crwdns2942667:0crwdne2942667:0 42,039
