Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
crwdns2936621:0crwdne2936621:0
Because I can't switch-off the tablet, I'm using the reset button to do this.
Now, remove the back cover.
Open the touchscreen flex cable connector and reconnect the cable.
They seem to have become aware of the problem at some point. My B1-A71 which was sent in for warranty a couple times has an additional green rubber square kind of thing holding the clip in tight, I notice your pictures don't have this.
crwdns2935229:015crwdne2935229:0
crwdns2947412:014crwdne2947412:0
Thanks.. it worked for my tab... Great...
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
It didn't work... I tried rebooting, restarting and taking out the flex cable and putting it back in. Any more suggestions?
Yes, I applied this method and its working now. Thank you for your support
Thank you for your sharing
I'm writing from Turkey ,
Greetings.
Miralge
Hey!!!!! 6 meses sin usar mi tablet y batallando para corregir el problema y me.encuenteo con ustedes!!!!! Merecen las graciassssssssss thank you colombia
thank you very much... my device is working now.... i'm from PHILIPPINES...
display not open
thanks, took 2 minutes and now working like new!
excelente, arregle mi tablet por tu video, fabuloso!!!
want my acer tablet fix screen jumping and letters typing
