Repair straightener ghd - Replace thermal fuse ghd
crwdns2936621:0crwdne2936621:0
  1. Repair straightener ghd - Replace thermal fuse ghd, remove the round covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, remove the round covers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lightly lift the round covers using your finger to create a small opening.
    • Insert a thin flat screwdriver, or a lever if you have one in this opening.
    • Lift by trial and error to avoid breaking the teeth of these covers which are fragile. If they break, don't panic, you can glue them.
  2. Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Sometimes these screws are mounted with screw glue. It is best to have two screwdrivers, including a small one for better control.
    • Start by unscrewing the screw by having the first screwdriver fixed on one side, and the other unscrewing on the other side.
    • screw it out, push the shaft and take it out.
  3. Repair straightener ghd - Replace thermal fuse ghd, Remove the plastic pin and the spring.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Remove the plastic pin and the spring.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the plastic axle with your screwdriver and take it out.
    • Remove the spring.
  4. Repair straightener ghd - Replace thermal fuse ghd, Unmount cache from branch and test: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Unmount cache from branch and test: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws from the button side cover.
    • Remove the cover equipped with the button.
    • The electronic card is now accessible. You can test the thermal fuse if you wish.
  5. Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 4 screws that hold the plate to the electronic board.
    • The thermal fuse is now accessible.
    • To remove the HS fuse, slightly pull out its cables as shown in the photo.
    • Using small pliers, scissors or nail clippers, cut the two cables.
    • You can now easily pull out the fuse head and cables on the other side.
  6. Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the 2 cables of the new thermal fuse.
    • Lift the tab and insert the fuse head.
    • Pull the two cables and press on the head to firmly press the fuse against the ceramic plate.
  7. Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Refit the plate on the electronic card using the 4 screws.
    • Do not forget to put the silicone part, which protects the electronic card against heat.
    • Refit the cover fitted with the button using the two screws.
  8. Repair straightener ghd - Replace thermal fuse ghd, Test run: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the straightener cable
    • You can now test the operation.
    • If you have a thermometer, the temperature should be between 180°C and 190°C. If you don't have one, turn on the straightener and let it heat up for 5 minutes to make sure everything is okay.
  9. Repair straightener ghd - Replace thermal fuse ghd, Final assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Final assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair straightener ghd - Replace thermal fuse ghd, Final assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can now reassemble everything:
    • First the spring, then the plastic axle, then the metal axle and finally the screws/washer and covers.
To reassemble your device, follow the steps in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Dr-lisseur.com
crwdns2935283:007/14/22crwdne2935283:0
153 crwdns2915208:0crwdne2915208:0
Bonjour j'ai un lisseur GHD le model est 4.2B , je l'ai brancher j'ai entendu 2 bip et plus rien , pensez-vous que c'est le fuisible qui est HS ? Cordialement
Laurent - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 102
crwdns2936753:030crwdne2936753:0 425
crwdns2942667:0crwdne2942667:0 17,571
