Repair a Broken Foot Pump
  1. Repair a Broken Foot Pump, Remove the gauge and hose: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair a Broken Foot Pump, Remove the gauge and hose: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the gauge from the pump. This isn't strictly necessary, but it makes the pump easier to work on.
    • Use scissors to cut off the damaged part of the hose.
    • If you are lucky, the good part of the hose is long enough to reuse. In the worst case you may need to get a new pump hose.
  2. Repair a Broken Foot Pump, Remove the metal collar from the hose: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This hose is held on to the pump with a crimped metal collar. By carefully prying up the crimped indentations with a small screwdriver, you can pull the hose out of the collar, preserving the collar for future use.
    • The jagged edges on the end of the pump body help to secure the hose. The crimped metal collar adds additional security when pumping at high pressure.
    • After removing the crimped metal collar, use small pliers to smooth out the crimp marks so the collar slides easily onto the end of the hose.
  3. Repair a Broken Foot Pump, Reattach the hose to the pump body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the metal collar back onto the trimmed end of the hose.
    • Push the free end of the hose onto the conical, stepped end of the hose.
    • Crimp the metal collar down to secure the hose. I used a small hose clamp to smash the metal collar in place. If you destroyed your metal collar or want the extra security, leave the hose clamp in place when you are done. I chose to remove the hose clamp to use for other projects.
  4. Repair a Broken Foot Pump, Reattach the pressure gauge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You are almost done. Reattach the pressure gauge by screwing it back onto the pump body.
    • Test the pump. Hold your thumb over the end of the pump head and step on the pump handle. The pressure gauge should rise and hold steady, and you should hear no hiss of escaping air.
    • If all is well, you are done. If air is escaping from the crimped hose end, be less cheap and permanently install the hose clamp.
crwdns2935229:05crwdne2935229:0
gordonhamachi
crwdns2935283:012/20/14crwdne2935283:0
3.774 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Thank you, will now try to repair my old favorite foot pump, hidden away somewhere in the garage.
Eddy Syms - crwdns2934203:0crwdne2934203:0
How can i find the metal part between pump hose and manometer
Usus - crwdns2934203:0crwdne2934203:0
Sorry, it isn't clear to me which metal part you mean. If it is what I call the thin metal collar, you don't need that at all if you leave the hose clamp in place to secure the hose to the pump body.
gordonhamachi -
Actually is not clear:).
I am referring to the metal part that si the hose and the manometer get in, after that they go in the body of the pump.
crwdns2936753:030crwdne2936753:0 129
crwdns2942667:0crwdne2942667:0 6,265
