Repair Broken LAN Socket "Click Retainer" RJ45 socket
  1. Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I purchased an "RJ45 Coupler" (Brand: Huakan) on Amazon. At the time of repair 6 couplers were sold for $6.99 ... now they are $9.99 (USA). These couplers have a thin stainless-steel frame on each side where the LAN cable "clicks" into the coupler.
1- Using a hacksaw blade, carefully cut lengthwise through the black ABS plastic covering. Use fine needle-nose pliers to peel-off the outer plastic layer. Use same pliers, to break/peel off the green rectangular circuit board.
  2. Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2- Clip the little stainless steel "nubs" from the flat sides (2-sides to each coupler, 4 total) ... also clip the black plastic "nubs" from the sides of the stainless-steel face frames. Gently push off the stainless steel face frames from the body of the RJ45 socket (2 of them).
  3. Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After separating the stainless-steel face-frames from the RJ45 Coupler, then note the red-arrow designated "prongs" that may be adjusted to give the best "fit" over the broken RJ45 socket. Adjust as needed to provide a deep-seated firm fit.
    • Clean stainless-steel frames with isopropyl (rubbing) alcohol, also swab the edge of the broken RJ45 socket. The new frame will cover green & amber LED lights, the lights are still partly visible when lighted or when flashing.
  4. Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 5- Slide the stainless-steel Frame over the existing RJ45 socket. The stainless-steel face frame has 2-prongs which can be made "snug" with tweezers (or similar) to provide a good fit over the edge of the existing (broken) RJ45 socket. TEST THE FIT ... adjust as needed, the stainless-steel prongs may need slight adjustment.
    • 5- I used "E6000" Industrial Glue/Adhesive (any hardware store). This makes a permanent bond . IMPORTANT: place only a very tiny amount of glue (pin-head) onto the stainless-steel face frame 'sides' (NOT the "click retainer" side) ... CAREFULLY fix the face frame in EXACTLY the alignment so the 'CLICK RETAINER' ALIGNs THE SAME AS ON THE SOCKET.
    • 6- SNUG the new stainless-steel face frame down to firmly/tightly SEAT IT to it's maximum tightness over the existing RJ45 Socket. NOTE: I pre-tested the connection by holding the stainless-steel frame in place with a small screwdriver, then plugging in the LAN cable and checking to make sure the connection was working (lighting up).
  5. Repair Broken LAN Socket "Click Retainer" RJ45 socket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 8- IF ALL IS WORKING ... PLACE A BIT OF 'DUCT-TAPE' in-place onto the RJ45 socket and snug the frame down as deeply as it will go. WAIT 24 HRS for full cure. NOTE: be VERY careful when placing the pin-head bits of adhesive,DO NOT spill or get adhesive onto the interior of the RJ45 socket connectors, for obvious reasons ;-).
Dennis in Cupertino CA
crwdns2935283:010/27/16crwdne2935283:0
87 crwdns2915208:0crwdne2915208:0
Thanks for the tip! I just repaired a Yaesu FT-891 socket that would have been a nightmare to de-solder and install a new jack. This should be just fine. Thanks again!
JKDEngineer - crwdns2934203:0crwdne2934203:0
I have to say, this is IMHO simply a stroke of genius and at the same time so weird nobody has thought of this fix before. There must be tons of idiots like me with a busted plastic socket on a device from a cable that got yanked out by accident. I just ordered a few of these couplers to salvage the faceplate. Thanks a lot for sharing!
Wim Meert - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 970
