Usa esta guía para remplazar el ventilador en el PlayStation 3 Slim
Dale la vuelta a tu PS3 y colócala con la parte trasera hacia arriba.
Con cuidado, quita la pegatina de la garantía, así podrás acceder al tornillo que se encuentra escondido debajo de ella.
Utiliza la parte plana de un "spudger" para hacer palanca en los siete puntos que se encuentran en el borde de la carcasa inferior y que esconden bajo ellos tornillos. Puedes observar en la imagen dónde están localizados.
Quita los siete tornillos Phillips de 37mm que sujetan la tapa superior de la carcasa inferior.
Quita los cuatro tornillos de seguridad Torx T8 de 13.3 mm que se encuentran debajo de la apertura del Blu-ray. (Algunos modelos solo cuentan con (3)tres tornillos)
Its 4 screws beneath the blu-ray
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening.
Can we edit this to say 4 screws?
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
Anyone know an online retailer with a competitive price for the replacement fan?
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
How do u buy the screw driver for these screws
Online at the usual suspects?
Or some hobby stores or places that sell tools will sometimes carry these.
Anyone else's screws for this step need the T7 bit instead of T8?
What is the name of this screwdriver
Levanta la tapa superior desde el borde trasero y rótala hacia la parte frontal de la PS3.
Quita la tapa de la PS3.
I just want to open the top cover to clean the fan. Do I need to unscrew the four security screws?
Aprieta el mecanismo que bloquea el conector del enchufe AC y tira de él hacia arriba para desconectar la fuente de alimentación.
Tira de los cables de salida de DC (corriente continua) hacia arriba para levantar su conector y sacarlo de su zócalo en la fuente de alimentación.
Those two screws are tight down there what do you recommend I use?
Desatornilla los dos tornillos Phillips de 7.6 mm que sujetan la fuente de alimentación a la carcasa inferior.
Question: if a screw doesn't come out, what do you recommend, without potentially damaging the system, inside and out?
It seems these can be quite tight, but they did come loose with someextra force in my case. They did that thing where it makes cracking sounds, but nothing really breaks. They're just really tight in there. - I just wouldn't recommend taking these out too often.
The screwdrivers on the guide didn't work mine just don't come out any tips model is slim CECH 2001A
Step 8
These screws work as a ground pass through between the motherboard shields and the power supply. My cousin took his PS3 to a repair shop to replace the power supply, they didn’t put the screws back in after that and the PS was shutting down suddenly (no light green or red), put a couple of new screws and it’s being working fine since
Sometime ago i took apart my PS3 out of curiosity, When puting it back together, i messed it up, I stripped one of the PSU screws. Now, i can't take it apart for a paste replacement. Any ideas?
The screws don't come out how do I fix this without breaking anything
I had the same problem with very tight screws on PS3 power supply. I solved it by purchasing a Screw removal / extractor gripping pliers long nose style , with unique non-slip jaws for quickly extracting damaged / stuck screws. ENGINEER PZ-60 Neji-Saurus,Silver. ( bought mine on Amazon)
These pliers have special grips on tapered end to hold and turn stripped or rusty screws. It took a lot of effort, but screws finally came out using these pliers. A bit of sewing machine oil and prising under the washers with a flat screwdrvers helps too. Failing that, take it to repair shop as they are VERY TIGHT screws on some models of PS3.
I need some advice I have taken apart my PS3 slim unit to clean it. I bought it second hand last year and it is filthy, I am having issues because the screws holding down the power supply are very tight, they are not stripped and I am using the right screwdriver. I don’t want to damage the screws, can anyone help?
Levanta la fuente de alimentación hacia arriba desde su borde izquierdo como se ve en la imagen.
Continua levantando el borde izquierdo de la fuente de alimentación hasta que salga de las dos patas metálicas que se ven en la segunda imagen.
Quita la fuente de alimentación de la PS3, ten cuidado de que ningún cable se quede enganchado en el proceso.
It seems it kind of ends for me here. I can only lift the left side about an inch and then the right side stays down like it’s stuck to something underneath. It feels like I’m bending something. Could something have melted underneath?… It's really stuck, I can't get it to come loose. And I can't see much shining a light into it either. - Any tips?…
Did you undo the screws?
I had the same issue but was able to get it off. The right side (as per the above picture) has two long column like sections that actually goes into the machine. Took me a bit of wiggling and some brute force.
You just lift the whole power supply up. There’s no need to start from the left? Is it possible to bend the two metal posts if lifting from the left?
Needs medium flat screw driver as wedge to help to lift the power supply in the right side or exert more force in your right arm provided the front of PS3 is at your front.
Um, I translated the guide from French to English and the name of the guide was “Food” and the description said “This guide shows you how to replace your diet” The translation is incorrect just to let you know!
Hi! Thanks for you attention! But no worries, the French word “alimentation” means power, food or diet depending the context.
Alright, thanks!
Jala los cables hacia arriba para desconectarlo de su conector en la placa madre
Saca los cables del ventilador de sus rieles plásticos
Remueve los dos tornillos Phillip de 9.5 mm que sostienen el ventilador al disipador
My PS3 doesn’t have the screws next to the fan.
My PS3 is dusty on the inside should I clean it with something? What should I use to clean it? So far I’m just removing the dust bunnies with my hands, and wiping the dust off with my fingers.
Eleva el ventilador afuera del disipador, teniendo en cuenta los cables que puedan quedar atascados
Para ensamblar tu dispositivo, sigue estas instrucciones en el orden inverso
crwdns2935229:061crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0Amaury Leonelcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2917034:0crwdne2917034:0
Andrew, excellent prestation.
Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
Travis Wheeler - crwdns2934203:0crwdne2934203:0
