crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Carefully remove back panel after all screws have been removed.
After the back panel has been removed, disconnect the battery to prevent electrical shock
Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
Once all the screws have been removed the battery is now safe to extract
Close the laptop, flip the laptop over, and pop off the back small panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
Use a T5 Torx screwdriver to remove the screws along the edge of the bottom cover.
Open the center cover and use a Phillips #00 screwdriver to remove single screw.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95-
Disconnect the battery to prevent electrical shock.
Disconnect yellow-colored ribbon cable from its port which sits at the bottom left of the fan housing.
Dislodge the CMOS battery.
Unplug CMOS cable.
Use a Phillips #00 screwdriver to loosen the screws that secure the heat sink's heat spreader.
Grip the heat sink from the sides and carefully lift it up to remove it.
Use a Phillips screwdriver to remove the two cooling fan screws.
The cooling fan can now be removed and a new one can be installed.
Use a Phillips screwdriver to remove the 4 trackpad screws.
Déconnecter les deux fils de la carte WiFi. Vous pouvez le faire à l'aide d'une pince ou de votre ongle.
Retirer la vis à l'aide d'un tournevis cruciforme #00.
Retirer à présent votre carte WiFi pour en faire le remplacement.
Retirer le disque dur de son emplacement.
Retirer la connectique avec l'aide d'une pince ou de votre ongle.
Retirer les vis à l'aide d'un tournevis cruciforme #00.
Retirer la carte par la suite.
Déconnecter les différentes connectiques de la carte-mère.
Retourner délicatement la carte-mère afin de déconnecter la nappe du clavier.
Vous pouvez à présent faire le remplacement de la carte-mère.
Retirer la vis à l'aide d'un tournevis cruciforme #00, puis le support.
Soyez patient et dévisser les 24 vis du clavier.
Vous pouvez maintenant retirer le clavier. Et également faire un nettoyage si nécessaire, comme sur la seconde photo.
