Removing the USB connector from a moulded cable
  1. Removing the USB connector from a moulded cable, Freeing the connector from the plastic: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the USB connector from a moulded cable, Freeing the connector from the plastic: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the USB connector from a moulded cable, Freeing the connector from the plastic: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The first step is to work on removing the moulded plastic from the metal. Start with the connecting line at the side using a utility knife. Once you completely cut the plastic from the both sides, push the utility knife between the metal and plastic as in the image to remove the plastic from the metal.
  2. Removing the USB connector from a moulded cable, Removing the plastic housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the USB connector from a moulded cable, Removing the plastic housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you pried the plastic housing from the metal part, carefully and slowly pry the plastic towards the back of the connector. The plastic will come off as in the image.
  3. Removing the USB connector from a moulded cable, Removing the fastener clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the USB connector from a moulded cable, Removing the fastener clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the fastener clips that go round the cable as pointed. Remove the clips using a nose plier.
  4. Removing the USB connector from a moulded cable, Removing the plastic completely: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the USB connector from a moulded cable, Removing the plastic completely: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In this step we completely remove the moulded plastic from the connector. Bear in mind that since the mould was hot, the plastic was in liquid form and thus dispersed throughout the connector. Remove the plastic carefully and if the plastic is stuck/stubborn, use the cable cutter to cut/remove it.
  5. Removing the USB connector from a moulded cable, Cleaning and finalizing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the USB connector from a moulded cable, Cleaning and finalizing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the USB connector from a moulded cable, Cleaning and finalizing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that we dismantled our USB connector from the moulded plastic, the remaining part is to clean up the remains -if any.
    • Before adding the connector to our spare parts, the final step is to make sure that all the pins are in working order. Visually inspect the pins and recheck they all work with a connectivity test in your multimeter.
Since the cable is of moulded type, we cannot bring the cable to its initial state.
crwdns2934873:0crwdne2934873:0
tr en
100%
crwdns2934883:0Tolga Balcıcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Tolga Balcı
crwdns2935283:012/02/24crwdne2935283:0
343 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 90
