Removing the Olympus Stylus 410 Outer Case
  1. Removing the Olympus Stylus 410 Outer Case, Slider: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the slider up until it comes off the upper track.
  4. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The slider should now be free from the body of the camera.
  5. Removing the Olympus Stylus 410 Outer Case, Outer Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case, Outer Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case, Outer Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Removing the Olympus Stylus 410 Outer Case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Olympus Stylus 410 Outer Case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
Jared Ruekberg
crwdns2935283:004/15/10crwdne2935283:0
33 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-13, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 6-13, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S6G13
crwdns2935297:017crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,726
