Removing fans
    1. Removing fans, Remove screws from bottom of laptop.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing fans, Remove screws from bottom of laptop.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    1. Removing fans, Remove the system board mylar: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing fans, Remove the system board mylar: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    1. Removing fans, Disconnect tape and cables: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
    2. Removing fans, Disconnect the fan cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the three fan cables from the system board by lifting away from board.
    3. Removing fans, Remove screws and fans: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
johann beda
crwdns2935283:009/13/10crwdne2935283:0
3,429 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 249
