Removing and replacing the grinder
    • Remove the lock washer on the axle for grinding degree adjustment using pliers.
    • Removing the lock washer requires some force. Don't hesitate to pull firmly.
    • Remove the grinding degree adjustment axle by using pliers to pull it upwards.
  1. Removing and replacing the grinder: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 screws on the bean container of the coffee machine with the Torx T10 screwdriver.
    • The screws are in a recess.
  2. Removing and replacing the grinder: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bean container.
  3. Removing and replacing the grinder: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pinion for the grinding degree adjustment.
  4. Removing and replacing the grinder: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 screws attaching the grinding mill attachment to the grinder with the Torx T10 screwdriver.
  5. Removing and replacing the grinder: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure not to rip any cables in this step.
    • Carefully lift up the grinder.
    • Disconnect the first connector (black cable) from the plug-in connector attached to the bottom of the grinder.
    • After you have removed the plug, you can carefully set down the grinder. For the next step you will need both hands.
    • Separate the second (white) cable attached to the grinder from the housing of the plug-in connector.
    • Carefully press on the housing of the plug-in connector.
    • Remove the grinder to clean or replace it.
    • Avoid putting the grinder down completely in this step, but hold it in your hand.
    • Reinstall the new or repaired grinder into the coffee machine.
    • Reconnect the grinder to the connectors. Make sure to place the connectors in the correct place.
  6. Removing and replacing the grinder: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now set the grinder back into its correct position
  7. Removing and replacing the grinder: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reattach the 3 screws for grinding mill by fastening them to the inserted grinder with the Torx T10 screwdriver.
  8. Removing and replacing the grinder: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinsert the pinion.
    • Make sure that the marking aligns with the center of the grinder, as the pinion is used to adjust the grinding degree and hence the strength of the coffee.
    • Reinsert the bean container into the coffee machine.
  9. Removing and replacing the grinder: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing and replacing the grinder: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fasten the two screws we remove from the bean container earlier with the Torx T10 screwdriver.
    • Reinsert the axle for grinding degree adjustment.
    • Use pliers to reseat the safety washer.
Need help closing the case of your Jura Impressa F50 coffee grinder? Check out the instructions "Close machine housing".
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Natalie
crwdns2935283:005/08/19crwdne2935283:0
747 crwdns2915208:0crwdne2915208:0
KMM 2019SS crwdns2935289:0KMM 2019SScrwdne2935289:0
Community
crwdns2931471:011crwdne2931471:0
I’ve got a similar Impressa machine to this one (the outside is visually identical). While removing the grinder, the ferrite inductor that is on the black wiring going into the grinder broke. Does anyone know what the rating/specs are of this inductor so I can splice in a replacement? The other similar inductor in the machine is unmarked and offers no hint as to what it’s ratings are. It’s been weeks since I broke the piece and I’m having a lot of trouble figuring this out.
Michael Zubi - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 237
crwdns2942667:0crwdne2942667:0 13,745
