Removing System board
crwdns2931587:0crwdne2931587:0
    1. Removing System board, Remove screws from bottom of laptop.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing System board, Remove screws from bottom of laptop.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    1. Removing System board, Disconnect battery cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    1. Removing System board, Remove battery screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      • Lift out the battery.
    1. Removing System board, Remove the system board mylar: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing System board, Remove the system board mylar: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    1. Removing System board, Remove the solid-state drive (SSD) shielding: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    1. Removing System board, Unscrew Solid-State Drives (SSD): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
    1. Removing System board, Remove the Wi-Fi card: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
      • Remove 1 silver 2mm PH1 screw (M2 x L2).
      • Remove the Wi-Fi card by pulling it away from the slot.
    1. Removing System board, Disconnect tape and cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
    2. Removing System board, Disconnect the fan cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the three fan cables from the system board by lifting away from board.
    3. Removing System board, Remove screws and fans: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
    1. Removing System board, Disconnect cables: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect 9 cables connected to the system board.
    2. Removing System board, Disconnect more cables: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect five more cables from the system board
      • Remove 3 black 4mm PH1 screws (M2 x L4) screws
      • Remove 2 black 6mm PH1 screws (M2 x L4) screws
      • Remove the flaps of tape holding the antenna wires to the board.
      • Remove the system board module carefully.
crwdns2955734:0crwdne2955734:0
johann beda
crwdns2935283:009/13/10crwdne2935283:0
3,429 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 206
