Open the tray by pressing the eject button
Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Press the eject button to insert the tray
After the tray is closed unplug DVD player
Pull the outer case upward and then towards you.
There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
Remove the three screws holding in the DVD tray
Remove the power cord and first two ribbons by pulling them directly out of their sockets.
Gently lift the DVD tray off of the motherboard.
Unscrew the 2 screws on the motherboard
Unscrew the 2 screws on the back
Disconnect the wires and ribbon by pulling them out of their respective connections
Lift board up and out of the lower case
