Removing RAM from HP Elitebook 6930p
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p, Battery Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p, Keyboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
    After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
    e5frog - crwdns2934203:0crwdne2934203:0
  4. Removing RAM from HP Elitebook 6930p: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing RAM from HP Elitebook 6930p: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
    There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
    Unless, of course, that your actually replacing the keyboard! In which case, remember to keep that rubber pointing device for replacing the one that you’ll probably eventually lose.
    Dennis - crwdns2934203:0crwdne2934203:0
  5. Removing RAM from HP Elitebook 6930p, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing RAM from HP Elitebook 6930p, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
crwdns2935229:022crwdne2935229:0
Richdave
crwdns2935283:004/09/10crwdne2935283:0
32 494 crwdns2915208:0crwdne2915208:0
crwdns2935297:030crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01 696crwdne2935297:0
crwdns2947412:07crwdne2947412:0
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - crwdns2934203:0crwdne2934203:0
I agree with above comment, weird thing to do.
S Cleaver - crwdns2934203:0crwdne2934203:0
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - crwdns2934203:0crwdne2934203:0
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - crwdns2934203:0crwdne2934203:0
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - crwdns2934203:0crwdne2934203:0
Hi. i would like to upgrade my notebook. i would like to buy 2 x 4gb pc2-6400 DDR2-800MHz soDIMM module. My question is… can i use this? Thank you !
Laszlo
laci1107 - crwdns2934203:0crwdne2934203:0
Yes. It is the best (and maximum) RAM combination, 8 GB DDR2 RAM. You may live with 6 GB, a cheaper solution (2 + 4 GB) is cheaper, better than 4 GB, but not as good as 8 GB. I'm using 6 GB now, and it is noticeable more responsive both in Linux Mint 21.2 or Windows 10 (2022). I just bought a 4GB DDR2-800 SODIMM at 23€ (postage+taxes incl.) at Aliexpress this month.
quim_rx -
crwdns2942667:0crwdne2942667:0 31,328
