Removing Olympus FE-210 Rear Casing
  1. Removing Olympus FE-210 Rear Casing, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Olympus FE-210 Rear Casing, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Rear Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Olympus FE-210 Rear Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Rear Casing, Front Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing, Front Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing, Front Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Rear Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Rear Casing, Rear Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Rear Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Olympus FE-210 Rear Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
Matt
crwdns2935283:001/25/11crwdne2935283:0
826 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-36, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-36, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G36
crwdns2942667:0crwdne2942667:0 2,790
