Removing Minolta X-370 Bottom Cover
  1. Removing Minolta X-370 Bottom Cover, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Minolta X-370 Bottom Cover, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - crwdns2934203:0crwdne2934203:0
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Minolta X-370 Bottom Cover, Bottom Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Nick
crwdns2935283:004/19/11crwdne2935283:0
525 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-7, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-7, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G7
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,150
