Removing JuiceBox from the wall
  1. Removing JuiceBox from the wall, Remove mounting screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On most installations, the JuiceBox is held to your wall using one screw between the two cable glands. Remove this screw.
    • After removing the mounting screw, lift JuiceBox straight up (parallel to wall) to unlatch it from the wall mounting tab. If you ever sell/give away JuiceBox, keep this wall mount tab with the box!
    • If your JuiceBox is hardwired, you would instead replace these steps with simply switching-off the breaker in preparation for the relay replacement work. To remove a hardwired unit from the wall, consult an electrician.
Matt Falcon
crwdns2935283:005/09/15crwdne2935283:0
2,677 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 786
