Removing Fender Frontman 15r Back panel
  1. Removing Fender Frontman 15r Back panel, Back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the top is separated, use your hand to remove the back panel from the unit.
Greg Sawers
crwdns2935283:009/27/12crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-30, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-30, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G30
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - crwdns2934203:0crwdne2934203:0
The way to get the electronics out is by removing the front panel, because removing them through the back is not possible because of the reverb unit. In case you need to disassemble a Fender frontman 15R, have a look at https://www.youtube.com/watch?v=ioQnwjgv...
repairchannel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,054
