Removing Dell Inspiron 15-7537 Bottom Cover
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Removing Dell Inspiron 15-7537 Bottom Cover, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Removing Dell Inspiron 15-7537 Bottom Cover, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Removing Dell Inspiron 15-7537 Bottom Cover, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Removing Dell Inspiron 15-7537 Bottom Cover, Remove the WiFi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover, Remove the WiFi Card: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  8. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two antennas (one black and one white) from the wireless card.
  9. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
  10. Removing Dell Inspiron 15-7537 Bottom Cover, Removing the Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  11. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  12. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  13. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the keyboard off the palm rest assembly.
  14. Removing Dell Inspiron 15-7537 Bottom Cover, Bottom Cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two black 5 mm screws underneath the keyboard using a Phillips head screwdriver.
  15. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer and remove the two silver 5 mm screws on the corners of the base cover with the Phillips head screwdriver.
  16. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three black 5 mm screws with the Phillips head screwdriver.
  17. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three silver 2 mm screws (with large flat circular heads) from where the battery was taken out with the Phillips head screwdriver.
  18. Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 15-7537 Bottom Cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a plastic spudger underneath the base cover and move it along the outside of the cover. Once the cover is disconnected lift the off the base cover.
    • To fully take off the base cover the wires that connect to the WiFi card need to be pulled off and pulled through its hole in the base cover
Jean Whitmore
crwdns2935283:001/22/15crwdne2935283:0
984 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-2, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-2, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 161
