Removing Dell Inspiron 1150 Optical drive
  1. Removing Dell Inspiron 1150 Optical drive, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Palm Rest: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive, Palm Rest: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Daniel
crwdns2935283:004/25/10crwdne2935283:0
87 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-2, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-2, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G2
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 5,980
