Removing Braven BRV-X Bottom Outer Casing
  1. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
  2. Removing Braven BRV-X Bottom Outer Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Braven BRV-X Bottom Outer Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Removing Braven BRV-X Bottom Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Braven BRV-X Bottom Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
Courtney Crockett
crwdns2935283:009/29/15crwdne2935283:0
360 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 19-4, Rauch Fall 2015 crwdns2935289:0Texas Tech, Team 19-4, Rauch Fall 2015crwdne2935289:0
TTU-RAUCH-F15S19G4
How do you remove the charging port
Neto - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,733
