Removing Bottom of iMac G4 15" 700 MHz EMC 1873
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
crwdns2935229:010crwdne2935229:0
Elliot Freerks
crwdns2935283:010/04/11crwdne2935283:0
923 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-32, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-32, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G32
Do I need to apply thermal paste? Or it is not necessary?
willynanita - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 6,987
