Remove Nintendo GameCube Optical Drive Assembly
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
    1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly, Top Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly, Top Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    2. Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
    1. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The left side of the unit contains the cooling fan and its housing.
      • Carefully remove the two screws attaching the cooling fan housing to the unit.
      • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
    2. Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four Phillips #1 screws retaining the ground springs.
      • Carefully remove the ground springs from the main unit.
    3. Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The optical drive is secured to a metal plate.
      • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
    4. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully separate the optical drive assembly from the rest of the GameCube unit.
      • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
      • The metal plate and the actual optical drive will remain attached.
dcarlin
crwdns2935283:011/05/09crwdne2935283:0
399 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-2, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-2, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G2
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,891
