Remove DeLonghi ECAM series top cover
  1. Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on the model, the steam tap/water spout must be removed, there are slight differences here.
    • Pull out the plastic clip on the steam nozzle.
    • Pull the steam nozzle out towards you.
  2. Remove DeLonghi ECAM series top cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove DeLonghi ECAM series top cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull off the steam faucet toggle. Only use a plastic tool to pry to avoid damaging the bezel.
  3. Remove DeLonghi ECAM series top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove DeLonghi ECAM series top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove DeLonghi ECAM series top cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you haven't already done so, also detach the right-hand cover on the water tank.
    • Remove the four Phillips screws securing the top cover.
    • Lift the top cover up a bit. That might be a bit sticky.
    • Don't remove the top cover completely, some models still have cables attached to the cup warmer.
    • If there is a cup warmer, then unscrew the nut SW7 with which the two green-yellow cables are connected and loosen it. The two brown cables on the other side can stay if you just put the cover on top.
    • Place the top cover on top, or remove it entirely.
Work the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
286,849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 2,378
