Remington S5500 Power Supply Cable Removal
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington S5500 Power Supply Cable Removal, Power Supply Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remington S5500 Power Supply Cable Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remington S5500 Power Supply Cable Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington S5500 Power Supply Cable Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
    It turns out this is really the only step you need to do to get at the plug for the wire. Remove the two screws and pop off the cover, remove the old swivel power connector and replace it. Put the cover back on and replace the two screws
    raoulrod - crwdns2934203:0crwdne2934203:0
  4. Remington S5500 Power Supply Cable Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington S5500 Power Supply Cable Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
Benjamin Yohe
crwdns2935283:007/11/18crwdne2935283:0
303 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G3, Wilson Summer 2018 crwdns2935289:0IUPUI, Team S3-G3, Wilson Summer 2018crwdne2935289:0
IUPUI-WILSON-SU18S3G3
Excelente trabajo! Muchas gracias por la información!
Ronnetto - crwdns2934203:0crwdne2934203:0
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - crwdns2934203:0crwdne2934203:0
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - crwdns2934203:0crwdne2934203:0
Howdy!
Turns out step 3 is really the only step you need to do. Remove the two screws that cover the swivel power connector. You don't need to mess with the hinge at all.
Picture of the power connector removed and hinge intact
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 7,450
