Remington MB4040 Thermal Switch Replacement
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
Cameron Carnahan
crwdns2935283:001/20/15crwdne2935283:0
1,112 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 1-5, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S1G5
crwdns2942667:0crwdne2942667:0 3,339
