Redmi Note 4 Screen and bracket Replacement
      • take out the sim tray
      • unscrew the two pentalobe P2 screws under the phone
      • use a suction cup and a pryer to open the phone(Very Heavy!)
    1. Redmi Note 4 Screen and bracket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • fingerprint cable
      • screen cable(display only)
      • power cble
      • buttons cable
      • unplug the power cable. it should be attached just by pushing , so just lift it.
      • unplug the screen cable. they are ZIF connectors.
      • you can test the new screen here, just by plugging the new screen cable, then the power cable
      • unplug the button cable, also ZIFs.
      • remove the battery using a hard rubber spatula.(it's got handle like IPhone's, but with china quality)
      • pry from the left bottom side. NEVER from the right side, or you might damage a cable.
      • remove the remaining glue from the battery, and re-tape it inside the white lines with tapes like TESA 2mm.
      • unplug antenna wire running down right side of phone to bottom mainboard.
    2. Redmi Note 4 Screen and bracket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Redmi Note 4 Screen and bracket Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • remove these phillips #0 screws on the upper board(forgot the number and the place, please add)
      • remove the vibration motor cover
      • remove the upper motherboard
    3. Redmi Note 4 Screen and bracket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • remove the phillips #0 screw from the lower casing
      • they're black, so easy to recognize
      • unplug all connectors(need photo)
      • use a hair dryer to heat the lower board(it's got glue)
      • be careful not to use force, the board is very fragile. If you feel hard to remove, heat it again.
      • Heat the borders of your screen to loosen the glue.
      • use a suction cup to open it.
      • the cables from the screen should all be detached at this moment
      • remove all the remaining glue from the plastic bracket (I mean all)
      • use tapes like TESA 2mm to re-glue the bracket.
      • you'll need to glue all the borders, but not around cameras, speakers, and proximity sensors.
      • Check the video I've linked to see where to glue.
      • reverse the steps and you should be good to go!
crwdns2935229:013crwdne2935229:0
sub ari
crwdns2935283:012/22/16crwdne2935283:0
470 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Where's the video? I can't find it on this page.
Roman Belyakovsky - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Redmi Note 4 lcd Jumper ways
Please!
KhinMaungphyo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I find the replacement screen for this model??
The screen I ordered have the connectors the wrong place and I can't find any replacement screen with BOTH wires on the bottom …
valerie langlois - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
you could buy a new screen in taobao
牛头与画像 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 28,761
