RedOctane X-Plorer Strum Bar Replacement
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using two hands, gently remove the two string rod fixtures.
    A step is missed here, there is a circuit board covering these fixtures. I ended up following the other guide on here to remove it then came back
    Zachary Avery - crwdns2934203:0crwdne2934203:0
  5. RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RedOctane X-Plorer Strum Bar Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the string rod by gently pulling it out of the strum bar.
Jared McMullen
crwdns2935283:004/18/18crwdne2935283:0
294 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G1, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S17-G1, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S17G1
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
crwdns2942667:0crwdne2942667:0 4,057
