RedOctane X-Plorer Motherboard Replacement
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Keys: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Keys: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RedOctane X-Plorer Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
Riley
crwdns2935283:004/18/18crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G1, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S17-G1, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S17G1
Where can I but a replacement board?
Matthew - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 3,016
