RedMax BCZ3050S Spark Plug Replacement
  1. RedMax BCZ3050S Spark Plug Replacement, Spark Plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look for the black plastic cover with ridges on the top of the brush cutter. Your fingers should be enough to pull the plastic off, but you may use a flat head screwdriver instead.
  2. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and separate the black plastic ridge covering from the spark plug..
    • Notice the spark plug still attached inside.
  3. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/8 in wrench to grip and twist the spark plug counterclockwise until it loosens and take it out.
    • You can use slip-joint pliers to perform the removal of the spark plug if you don't have a wrench.
  4. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the new spark plug and twist it in a clockwise motion until it is tight.
  5. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the wrench or pliers and twist the spark plug in a clockwise direction to ensure a tight fit before placing the cover on top of the spark plug.
  6. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the bottom of the plastic cover to the top of the spark plug.
    • Firmly push down on top of the spark plug with the cover. This is enough pressure to connect the new spark plug to the machine.
  7. RedMax BCZ3050S Spark Plug Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cover is fully inserted, the repair is complete.
Saul Aceves
crwdns2935283:010/13/20crwdne2935283:0
166 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S2-G3, Willis Fall 2020 crwdns2935289:0University of Memphis, Team S2-G3, Willis Fall 2020crwdne2935289:0
UM-WILLIS-F20S2G3
No, you use a spark plug socket to remove a spark plug.
Jose - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 878
