RazorX DLX Electric Skateboard Wheel Motor Replacement
  1. RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Wheel Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Control Module by lifting it out of the plastic housing.
  10. RazorX DLX Electric Skateboard Wheel Motor Replacement, Wheel Motor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RazorX DLX Electric Skateboard Wheel Motor Replacement, Wheel Motor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the grommet out of the plastic case.
    • Slide the cables through the grommet.
Emmett Normand
crwdns2935283:010/24/24crwdne2935283:0
971 crwdns2915208:0crwdne2915208:0
Cuesta, Team 20-4, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 20-4, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S20G4
crwdns2942667:0crwdne2942667:0 67
