crwdns2959928:0crwdne2959928:0 ↓After using the scooter for a long period of time, one of the wheels may deform, develop flat spots, or crack in some areas, resulting in a rough ride for the user. This guide will show you how to replace a wheel on your scooter, returning it to its original glory.
×2
Flip the scooter upside-down with the handlebars and brake on the ground.
Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
Once both screws are removed the wheel should be free and fall out.
Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
Put the replacement wheel into place in the scooter frame.
