Razor A Handle Grips Replacement
crwdns2942287:0crwdne2942287:0Do your hands hurt or slip when riding your scooter? Chances are your handle grips need to be replaced. This guide will show you how.
crwdns2944105:0crwdne2944105:0
Locate the handle grips at the upper ends of the T-tube.
Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
Repeat for the other handle grip.
Soak the replacement handle grips in warm water for 2-3 minutes.
Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
Repeat for the other handle grip if installing both.
Let the handle grips dry for 24 hours before use.
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
