This guide will show you how to disassemble the entire controller to access all of the control boards.
I had to replace my bumper switch (SW54 & SW55) with Omron B3F-3120
Use a plastic pry tool to remove the grip plate from each side
The plate will release away from the back, not to the side
Cut the sticker covering the center screw and remove it (PH #1)
Remove two screws from each grip (PH #1)
Use a plastic pry tool to remove rear plate from the controller
The three remaining screws on the back plate are PH #1
Remove the M1 & M2 bumpers with two PH #1 screws (red)
Unplug the four rumble motors (green)
Unscrew the board from the controller with two PH #2 screws (blue)
Carefully flip the board until you can get to the ribbon cable
Flip the gray clip up to release the ribbon cable
Remove the two PH #00 screws to remove the trigger brackets
Slide the trigger pin out just enough to remove it, leave the spring attached
The three remaining screws on each trigger are PH #1
Remove the bumper assembly from the controller
The bumpers detach with two PH #1 screws
I have done everything, but how do i remove the thumbstick plastic, it would be very great if you can guide me
I didn't remove my thumbsticks. They are likely glued on. You could try to pry them off or use heat but you are on your own for that.
Drew -
You can´t change the thumbsticks, they are stuck and impossible to remove. I broke one of them trying to get it out. It's okay because I want to replace them with magnetic ones and I'm looking at how to do it and compatible modules.
