Razer Viper Mini Scroll Wheel Replacement
  1. Razer Viper Mini Scroll Wheel Replacement, Remove Information Sticker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Remove Information Sticker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Make sure to unplug the mouse before doing anything.
    • Turn the Mouse Over so the bottom is facing up.
    • Remember to take a photo of your serial number or write it down
    • Take off the information sticker and the plastic cover from the bottom of the mouse.
  2. Razer Viper Mini Scroll Wheel Replacement, Remove Baseplate Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Remove Baseplate Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the three 2 mm screws from the bottom of the mouse.
    • When removing the screws, unscrew them each slightly and consecutively until you can pull them out with your hands.
  3. Razer Viper Mini Scroll Wheel Replacement, Detach backplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Detach backplate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Detach backplate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic spudger to gently lift the backplate from the mouse shell.
    • Insert the spudger into the bottom back of the mouse and slowly move it around the mouse to release the backplate.
    • Do not try to push or jab the mouse with the plastic spudger with a large amount of force, this can damage the plating of your mouse.
  4. Razer Viper Mini Scroll Wheel Replacement, Remove shell: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Remove shell: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic spudger once again to remove the top shell of the mouse.
    • It is similar to the previous step, as you have to pry the plastic spudger gently into the bottom of the mouse and move it slowly inwards and upwards to release the shell.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the cable.
  5. Razer Viper Mini Scroll Wheel Replacement, Disconnect the Ribbon Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Disconnect the Ribbon Connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon connector between the motherboard and the USB cable by squeezing the connector and pulling up.
    • Pulling too hard could damage the wire connections.
    • Pulling by the ribbon instead of the connector can dislocate the wires.
  6. Razer Viper Mini Scroll Wheel Replacement, Unscrew Motherboard from Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove 2 5.5 and 3 2.5 mm screws.
  7. Razer Viper Mini Scroll Wheel Replacement, Remove Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard by grasping the sides and gently pulling upward.
  8. Razer Viper Mini Scroll Wheel Replacement, Remove Scroll Wheel from case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Viper Mini Scroll Wheel Replacement, Remove Scroll Wheel from case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the scroll wheel from the socket by pulling to the right.
    • Pulling too hard could damage the scroll wheel connector.
crwdns2935229:05crwdne2935229:0
Addison
crwdns2935283:008/30/19crwdne2935283:0
3,024 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
University of North Texas, Team S1-G3, Friess Fall 2019 crwdns2935289:0University of North Texas, Team S1-G3, Friess Fall 2019crwdne2935289:0
UNT-FRIESS-F19S1G3
crwdns2935297:038crwdne2935297:0
When we remove the scroll wheel, can we get the scroll wheel for it?
مسعود مهنانی - crwdns2934203:0crwdne2934203:0
Kevin Lee Pagulayan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 173
crwdns2942667:0crwdne2942667:0 16,271
