crwdns2959928:0crwdne2959928:0 ↓Having wireless connection problems with your Razer Phone and you need to replace the motherboard? To replace it follow this guide.
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Pry the top plastic grill off with the metal spudger and reveal the screws.
Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
Lift the display assembly away from the other half of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
Peel back the metallic shielding over the connector using tweezers.
Remove the metal bracket connector.
Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
Grab the bracket with the tweezers and remove it.
Peel off and pull out the elastic tabs at the bottom of the battery.
Carefully use the Jimmy to wedge the battery out of the phone.
Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
Remove the protective peel covering the rear cameras using your hands.
Use the tweezers to remove the white tab connector.
Grab and remove the metal tab with the tweezers.
Grab the connectors with the tweezers and gently lift the connectors loose.
Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
Grab and remove the blue connector with the tweezers.
Remove the five 1 mm screws holding down the gold antenna line brackets to the motherboard using the Phillips #000 screwdriver.
Remove the 2.5 mm screw next to the front-facing camera with the Phillips #000 screwdriver.
Remove the four gold antenna line brackets with the tweezers.
Using the tweezers remove the SIM card tray from the body of the phone.
Carefully lift up the motherboard away from the device.
