Razer Phone Battery Replacement
  1. Razer Phone Battery Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    Double sided tape can be used to adhere the grills in place.
    Lucano - crwdns2934203:0crwdne2934203:0
    How to make the Another adhesive??? Plz rply
    My razed Phone Speaker grills can't put again Perfectly
    Ferdi Pongbubun - crwdns2934203:0crwdne2934203:0
    Where can i find a Charging Connector for Razer Phone 2 to buy….becouse the only place i când find IT is in India and they only delyver to
    curteanuice13 - crwdns2934203:0crwdne2934203:0
  2. Razer Phone Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    Hi you got any screen for sale thanks
    anwarhussain21786 - crwdns2934203:0crwdne2934203:0
  6. Razer Phone Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    I would highly recommend avoid using metal tweezers for this step.
    Otherwise, be EXTREMELY careful with them when near the contacts around the ribbon cable.
    With the battery still plugged in, trying to unplug the ribbon connector of the screen with a metal tool will cause shorts between the tiny contacts.
    John Li - crwdns2934203:0crwdne2934203:0
  7. Razer Phone Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    Careful.
    There's actually 2 screws you need to remove with this step before you can remove the bracket..
  9. Razer Phone Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    It isn’t necessary to remove the battery.
  10. Razer Phone Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Phone Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully use the Jimmy to wedge the battery out of the phone.
    battery razer phone 1 and 2 is the same type?
    my phone is razer phone 1, and only see online shop selling the battery for razer phone 2
    Alpha Jon - crwdns2934203:0crwdne2934203:0
    Where I can get the design specs for the razer phone 1 battery? I think they are not producing it anymore…
    h_yilei - crwdns2934203:0crwdne2934203:0
    It is 376989 in size I brought a 396787 but without the BMS board specs still cannot fix it.
    And also what is the Panasonic 777156? It has 6 pins under it, it seems not like a capacitor and cannot find replacement on digi-key.
    I used this guide to replace my battery for my Razer 2 phone and the front speaker grills have no screws at all. Had to access the battery from behind the phone. So apparently I have a different version of Razer 2 phone. So followed another guide and replaced the battery. Unfortunately, I had to deal with the speaker grills.
    Nick T - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Bryan
crwdns2935283:001/24/19crwdne2935283:0
777 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G6, White Winter 2019 crwdns2935289:0Cal Poly, Team S19-G6, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S19G6
crwdns2947412:05crwdne2947412:0
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - crwdns2934203:0crwdne2934203:0
Where can I buy a battery and power button replacement for this phone
Kelly Sales - crwdns2934203:0crwdne2934203:0
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - crwdns2934203:0crwdne2934203:0
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - crwdns2934203:0crwdne2934203:0
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto -
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 18,211
