Razer Ouroboros Battery Replacement
  1. Razer Ouroboros Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
    There’s also a version that has no screws to undo, just disregard the second step and follow the rest of the guide
    Bryan Russ - crwdns2934203:0crwdne2934203:0
  2. Razer Ouroboros Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
    For the people confused and don't have screws on the back plate press on the circle piece picture # 2 not the actual circle but the plastic around it you don't have to pull any screws out you're welcome 🤗
    stephen lantz - crwdns2934203:0crwdne2934203:0
Brandon Jones
crwdns2935283:007/19/16crwdne2935283:0
308 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-2, Kim SU 2016 crwdns2935289:0University of Memphis, Team 1-2, Kim SU 2016crwdne2935289:0
UM-KIM-SU16S1G2
crwdns2947412:08crwdne2947412:0
is the battery a standard AA battery size or did they use a different size?
adiforipod - crwdns2934203:0crwdne2934203:0
… what happens if I don't use a rechargeable battery?
Russell Phillips - crwdns2934203:0crwdne2934203:0
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - crwdns2934203:0crwdne2934203:0
I don’t have the screws on the bottom of my mouse wtf!
Miika mon - crwdns2934203:0crwdne2934203:0
The screws don’t actually need to be removed you only need to hold down the button that adjusts the length.
Shane Madden - crwdns2934203:0crwdne2934203:0
You should specify that this mouse uses NiMH and not Li-ion batteries.
Samuel Hunter Logan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 20,393
