Razer Naga Trinity Disassembly
  1. Razer Naga Trinity Disassembly, Razer Naga Trinity Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Naga Trinity Disassembly, Razer Naga Trinity Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Naga Trinity Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Naga Trinity Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Naga Trinity Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top housing LED 3-Pin connector that is near the main board.
crwdns2935229:019crwdne2935229:0
Alexandros Andreou
crwdns2935283:009/16/19crwdne2935283:0
712 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G2, Salas Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G2, Salas Fall 2019crwdne2935289:0
ERAU-SALAS-F19S6G2
crwdns2935297:013crwdne2935297:0
crwdns2947412:011crwdne2947412:0
I would like to to point out that at step 7, second picture, the 3-pin connector is for the top 2 buttons. the RGB LED is actually in the board and can be seen in step 7 first picture, tiny white square at the bottom, top left where it says K7-D1.
Jaidee Sasaki - crwdns2934203:0crwdne2934203:0
The cable for the Naga2014 fits admirably and appears to work fully, BUT NOTE: the green and white wires need to be swapped around in the plug at the end that connects inside the mouse.
Chris Gravell - crwdns2934203:0crwdne2934203:0
How do you open up the side plates so you can clean inside them?
Teach - crwdns2934203:0crwdne2934203:0
If you feel along the back, you'll notice that it is 'rougher' than the injection-molded plastic; this is a sticker that hides 4 Phillips #1 screws and two more magnets. Peel off the sticker and remove the screws--the plate should then lift right out. I... discovered this the hard way after destructively disassembling a broken 12-button part because the design LOOKS like it just clips on, and I wasn't sure if this was a heat glue situation or something else. Here's the 6-button part fully disassembled. https://i.imgur.com/xK7IPus.jpg
Warmachine (Warmachine) -
How do you remove the board so that you can replace the mouse buttons when they break?
kbenaca654 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 368
crwdns2942667:0crwdne2942667:0 37,063
