crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Remove the four 7mm screws using a Phillips #00 screwdriver.
Gently remove the top plastic plate of the mouse.
Unplug the white cord from the circuit board.
Lightly pull the two plastic sides of the mouse to remove them.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Unplug the cord that connects the scroll wheel to the motherboard.
Slide the chip out of the scroll wheel.
Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
Use your thumbs to pop the scroll wheel out from its plastic frame.
Place the new scroll wheel in the mount.
Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
Place the new motherboard in the mouse.
When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
crwdns2944067:04crwdne2944067:0
Surprised this is rated Difficult. :f
Do you know where I can find the motherboard for the mouse?
Where can I get a replacement motherboard?
I followed these steps for the razer naga hex and it's the same. Just a tip for people that want to take off the teflon tapes, you don't need to take off the big one to the side, the only 4 screws holding the case to the top part of the mouse are under the 4 small teflon tapes in each corner. Good luck!
