Razer Naga Epic Chroma Battery Replacement
  1. Razer Naga Epic Chroma Battery Replacement, Mouse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
    Thank you for this guide! I was able to get my mouse from 2014 open and clean it out
    Spam Account - crwdns2934203:0crwdne2934203:0
  5. Razer Naga Epic Chroma Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
    Also, you’ll want to carefully remove the foam from the battery for reuse.
    Dan Mergens - crwdns2934203:0crwdne2934203:0
  6. Razer Naga Epic Chroma Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord from the circuit board in the mouse.
    Did you find a replacement? Couldn't find a dealer for this battery
    Doc Brown - crwdns2934203:0crwdne2934203:0
    Reposting from below: https://www.amazon.com/gp/product/B0767K... - for this battery you’ll need to switch the battery leads to match the polarity.
    Dan Mergens -
    Also, you should remove the tape, or provide your own for the replacement battery.
  7. Razer Naga Epic Chroma Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
Jordan Morgan
crwdns2935283:001/19/17crwdne2935283:0
895 crwdns2915208:0crwdne2915208:0
Arkansas State University, Team 1-4, Chamberlain Spring 2017 crwdns2935289:0Arkansas State University, Team 1-4, Chamberlain Spring 2017crwdne2935289:0
ARSU-CHAMBERLAIN-S17S1G4
crwdns2947412:013crwdne2947412:0
Do you have battery for sell?
BcTwenty9 - crwdns2934203:0crwdne2934203:0
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Dan Mergens -
Anyone know where to buy a new battery?
Antony Lynch - crwdns2934203:0crwdne2934203:0
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
Gooly - crwdns2934203:0crwdne2934203:0
that battery appears to be very swollen………
Levi Coffey - crwdns2934203:0crwdne2934203:0
I believe the battery model is FT112943P
tiago.carvalho.leite - crwdns2934203:0crwdne2934203:0
Any battery that’s 3.7V should be fine, I bought this battery from amazon. The only thing I need to do is to switch positive and negative terminals.
ak48disk - crwdns2934203:0crwdne2934203:0
I have some spare Dualshock 4 controller batteries, which are basically 1S lipos, like the one in this mice.
I am just concerned about the protection circuit which tha original battery has, because the DS4 battery has a plastic case.
My question would be: Can I use the PS4 controller battery if I manage to hack it into the mice somehow, or would it be dangerous?
Felder Szabolcs - crwdns2934203:0crwdne2934203:0
UPDATE: I just disassembled a PS4 controller’s battery, and without a case, you can fit a battery in the naga, but You need to change te + and - wires, and you have to solder in longer wires, but it works.
Felder Szabolcs -
Will this battery work( size wise). The one ak48disk suggested will not ship outside US.
https://www.amazon.com/dp/B0767CWB1X/?co...
philip lee - crwdns2934203:0crwdne2934203:0
just removed my old battery and it looks exactly the same like on the pictures above, ordered new one and will assembly it tomorrow. Easy to find on amazon, bought 4 batteries for 18GBP. Wanted only one but Amazon was having them only in packs. Went for a smaller one tbh, as the 2000mah would not fit into the mouse so I’m having 1000mah which will be fine for me as my sessions are not long and I use it mostly on wire. If u need advice email me at dafff1991@gmail.com I’ll be happy to help. Regards, Dawid
Iksilak - crwdns2934203:0crwdne2934203:0
Is it the one linked? For me it is unavailable for the last few days or did you get it from another place?
Deniz Altug -
You left out the step where you order the wrong battery and have to wait three days for the right one to arrive. :-) Thanks for the help.
Digital Dan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 15,484
