If your Razer Naga Epic Chroma Mouse doesn’t respond properly or continues to turn on and off at random times, it’s likely due to a faulty battery.
Prior to this guide make sure to check the troubleshooting guide as other problems are caused by these issues as well. Be sure to check all the Razer Naga Epic Chroma Guides for more information related to troubleshooting your mouse.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
            Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
            Use a Phillips #00 screwdriver to remove the four screws.
            Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
            Gently pull up on the right plate on the mouse; separating it.
            Carefully repeat this step for the left side.
            Take your nylon spudger to gently pry the battery pack from the device.
            Remove the foam on the battery shell for your new battery.
            Unplug the power cord from the circuit board in the mouse.
            Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
            Insert the new battery into the battery socket.
            Place the foam on the surface of the new battery (reference Step 5).
crwdns2947412:013crwdne2947412:0
Do you have battery for sell?
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Anyone know where to buy a new battery?
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
that battery appears to be very swollen………
