Razer Huntsman Tournament Edition Port Replacement
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
    You forgot about the screw near the USB-C socket you need to unscrew the screw from the back of the case, it is under the sticker!
    альpha&ωμέγα - crwdns2934203:0crwdne2934203:0
    The Phillips #0 head is actually too big and can strip the screws, the #00 is a better fit
    James Rudd - crwdns2934203:0crwdne2934203:0
  6. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
    This is sorely lacking. After taking out the thirteen screws on the top plate, there is a hidden screw under an inconspicuous sticker (that's textured to look just like plain black plastic) facing the USB type-C port. Peel that sticker to reveal the screw and unscrew it before attempting to lift the top plate off.
    Abe - crwdns2934203:0crwdne2934203:0
  7. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Tournament Edition Port Replacement, Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the USB board.
Joseph O'Dowd
crwdns2935283:010/25/22crwdne2935283:0
383 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 4-3, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S4G3
how do i get a new port and where
Guardian Suit - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 465
