If your port is either wobbly or non-functional, use this guide to replace it. This guide should take a half hour.
The Razer Huntsman Tournament Edition is a tenkeyless mechanical keyboard. Its USB port is easily swappable, being held in by a screw and a cable.
You must know how to remove the back of the keyboard before beginning this guide.
Place the unplugged keyboard on a flat, clean surface appropriate for working on.
Grip the keycap with your keycap puller.
Pull with an upwards force to remove the keycap.
Remove all of the keycaps with a keycap puller.
Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
Use an opening tool to pry open the chassis.
Unscrew the board with the port.
Detach the internal cable from the USB board.
how do i get a new port and where
