If either your switch action is undesirable, the LEDs aren't working, or the key function isn't working at all, you may want to replace the switches. This guide should take well over an hour.
The Razer Huntsman Tournament Edition is a tenkeyless mechanical keyboard.
You must know how to remove the case in order to complete this guide.
Place the unplugged keyboard on a flat, clean surface appropriate for working on.
Grip the keycap with your keycap puller.
Pull with an upwards force to remove the keycap.
Remove all of the keycaps with a keycap puller.
Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
Use an opening tool to pry open the chassis.
Gently push the key switch off of the mainboard with your thumb.
