This guide will allow you to access the internal components of the Razer Huntsman Tournament Edition. This guide should take over an hour.
The Razer Huntsman Tournament Edition is a tenkeyless mechanical keyboard.
You must know how to remove keycaps in order to complete this guide.
Place the unplugged keyboard on a flat, clean surface appropriate for working on.
Grip the keycap with your keycap puller.
Pull with an upwards force to remove the keycap.
Remove all of the keycaps with a keycap puller.
Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
Use an opening tool to pry open the chassis.
