crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Razer Huntsman Elite Gaming Keyboardcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Razer Huntsman Elite Gaming Keyboard Teardown, Overhead View: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Top view of the keyboard.
  2. Razer Huntsman Elite Gaming Keyboard Teardown, Remove Key Caps: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all key caps by pulling them directly upwards.
  3. Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Front Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Front Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 18 JIS-1 screws in-between key switches. Remove all screws (see red circles). Be extremely careful if using a Phillips-1 instead of a JIS-1 as Phillips screwdrivers can destroy JIS screws.
  4. Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Back Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Remove All Back Screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Under the six rubber pads are eight JIS-1 screws that need to be removed. The edges of the pads can be lifted to access the screws without having to remove the entire pad. Using a small flat-blade screw driver can help with lifting the corner(s).
    • Gently pry the black cover up away from the main body. Be careful not to damage the wires.
    • I apparently forgot to take pictures of this step.
  5. Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Remove LED Light Logic Board Screws: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Nine JIS-1 screws secure the back LED logic board. Remove all of them.
    • The back LED logic board is connected to the main PCB by a cable. Carefully disconnect the cable.
  6. Razer Huntsman Elite Gaming Keyboard Teardown, Pry Open the Plastic Panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The transparent plastic gasket is tightly locked to the main frame via small plastic tabs all around the outside edge. Use the jimmy tool to carefully remove the panel.
  7. Razer Huntsman Elite Gaming Keyboard Teardown, Remove Main Frame Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Remove Main Frame Screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are three tiny JIS-000 screws that keep the main frame and the printed circuit board together. Remove the red circled screws before you separate them.
  8. Razer Huntsman Elite Gaming Keyboard Teardown, Disconnect Printed Circuit Board (PCB) Board Cables: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Huntsman Elite Gaming Keyboard Teardown, Disconnect Printed Circuit Board (PCB) Board Cables: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two cables connected to the PCB. Carefully separate the main frame and the PCB, then disconnect the lower cable first.
    • With the lower cable disconnected, the PCB can be flipped upright so as to easily remove the upper cable.
  9. Razer Huntsman Elite Gaming Keyboard Teardown, Logical Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the logic board is revealed and can be cleaned up.
Will Huang
crwdns2935283:007/22/19crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
are the actual keys soldiered to the board or they are hot replaceable?
Tawshif Ahsan khan - crwdns2934203:0crwdne2934203:0
The switches have no electrical contacts, they are only mechanical components. The LED and photodiode that read each switch are soldered to the main PC board. So to answer your question: no, the switches are not soldered to the PCB.
Enrico Savazzi -
Does anyone know what kind of LED's are being used on this keyboard? The green on one of the LED's has burned out and I would like to replace it.
Valentino Damianou - crwdns2934203:0crwdne2934203:0
Anyone know if the rotary dial can be replaced? Mine does not act properly and turning it in one direction causes changes in value that are both inconsistent in value and direction. Very weird.
Armando Wirshing - crwdns2934203:0crwdne2934203:0
Just use some WD40 on it, I did it, had the same problem and it fixed it.
Jonathan José Ramírez Zaragoza -
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 314
crwdns2942667:0crwdne2942667:0 21,376
