The Razer DeathAdder Chroma may experience critical issues related to the device not being registered by the computer via a fault in the USB cable.
Turn the mouse over so the bottom is facing up.
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
Use your fingers to identify the location of the screw under the bottom label.
Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
Disconnect the ribbon connector between the motherboard and the optical sensor.
Remove the motherboard by grasping the sides and gently pulling upward.
Remove the USB cable by pulling it up and out.
crwdns2935229:08crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the advice
João Costa Santos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where can i get the cable from?
Mourya Singham - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
