The optical sensor for the Razer DeathAdder Chroma is a crucial component for the device’s operation. A critical failure of the optical sensor will necessarily require a replacement.
Turn the mouse over so the bottom is facing up.
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
Use your fingers to identify the location of the screw under the bottom label.
Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
There are 2 tiny locking pins at the back you may need to spudge the connector casing a bit on each side to release these , I did.
Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
Does anyone know what the circuitry this screw holds in place does, I completely missed this tiny screw and accidently snapped the 2 soldered components off named D2 & D3… But the mouse still works fine ?? however i do not use razer synapse anymore so i dont know if its 100% working
Never mind it just came to my attention there is a set of LEDs in the mouse wheel which is what that tiny board is, soo …. RIP Mouse Wheel LEDs
Disconnect the ribbon connector between the motherboard and the optical sensor.
Remove the motherboard by grasping the sides and gently pulling upward.
Use a Phillips #0 screwdriver to remove two 5.5mm screws.
Remove the optical sensor by pulling it forward and up.
crwdns2935229:05crwdne2935229:0
Where do I get the part?
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
